Camera settings
I am a new Typhoon H owner and I have just completed the latest firmware update. I am unable to find if there is a button/switch to press or a setting that will fix my camera to face the front of the drone itself. I would basically like to rotate the drone left and right instead of the gimble so I can keep my drone orientation until I become a better pilot. Is there any way for me to do that?
Make sure the two toggle switches (Gimbal Pan Mode & Gimbal Tilt Mode - switches 02 & 03) on the upper left of the controller are all the way up and also make sure the Gimbal tilt controller at the back left (18) is all the way up. This will center the camera to point forward and level.
Reactions: Gomi
Thanks so much for your help
Rank Li
