CG02 wiring plug locations
After a crash, my CG02 camera came loose from the shock mount breaking off 2 JST plug connectors from the board. I sent the board for micro repairs to ipadrehab. Upon return, I will have the problem of which wire plug goes where?
Does anyone have a wiring diagram of where each wire set from the camera plugs into the board that is above the shock mounts?
I plan on attaching the shock mount to the camera with small wire ties to limit how far the camera can come off the shock mount in a crash; this will limit the distance to shorter than the wires.
Is this what you need? The PDF version may be easier to read.
  • CG02 Harness to Camera Wiring R4.pdf
bancadoithuongads
