I would love to able to use my typhoon h camera as a handheld one as well, does the old CGO3 steady grip work? can i just buy one off ebay and have it work? will yuneec make one for the CG03+?
How much yaw do you need?The camera from the H is longer when mounted, I had it connected but it did not yaw fully because the camera would touch the base of the grip.
Is yours like that? Can you show a side profile of your mod?
That one WONT WORK!So it works out of the box but uses up to much power so you have to do the battery mod? that's strange. I just want to be be stabilized and able to use the camera without carrying around the entire drone and st16 and don't need to pan down all the way so this should work. but i am confused on which one to get off ebay with people saying there are multiple versions will this one work?
BRAND NEW YUNEEC CG02+ CG03 GB203 STEADYGRIP STEADY GRIP HAND HELD GIMBLE MOUNT
Short answer is no not all of steady grips are the same if it has a socket for the camera to plug into then it wont work.
What to look for this is a photo mine and it has the socket for camera to plug into this wont work with the Typhoon H.
If it has the socket it will work if it also has the slide connectors. Its the ones with the socket but no slide connectors that will not work with the CGO3+ that comes with the Typhoon H.Short answer is no not all of steady grips are the same if it has a socket for the camera to plug into then it wont work.
If you are having trouble using the gopro gimbal, there is a problem with your slide connector. Your tabs/terminals are probably bent. Try using the short adapter wire and connect between the gimbal and the Steadygrip.I purchased a steadygrip which came with a gimbal for a gopro, and has a little socket to connect the gimbal to the grip. when i connected my CGO3+ to it, it stabilised but i couldnt connect my phone to it. am i doing something wrong, or is the gimbal wrong??
If there is rubber covering the area where the slide connector should be.....i did not see any on ebay with pins on the slide connector just ones with the connector without pins and some with a cover on the slide connector
