- Joined
- Jun 22, 2017
- Messages
- 85
- Reaction score
- 15
- Age
- 61
I have a CGO something Plus or Pro...Just firmware? My question is..is there a Steady Mount thingy that works with this cam? Thanks in Advance
The early versions of the SteadyGrip used AA batteries but the drained so quickly it was nearly unusable. Most people that use then have modified them to work with a 11.1v Lipo. It's an easy conversion.That is great to know. Thanks. What I am concerned about is I have seen something about several versions? and some not compatible with the Plus or Pro model. Also the powering options...some appear to have replaceable batteries and some have rechargeable? thanks in advance
OK I am starting to sort it out lol I think....I couldn't find one on Yuneec website for sale under accessories....
I am not finding this one for sale at yuneec. Where did you get yours?
The SteadyGrip is the model with the black lower handle/battery compartment that is powered
by 8 AA batteries. The ActionGrip is the one that has a silver lower handle/battery compartment
that is powered by a lipo. Both only have 3 contacts, and only tilt functions. You are the pan
mechanism. Both cameras connect and work on either grip.
The greater difficulty is getting the app to sync with your specific device, and the solution has been
found to be getting a previous version of the app. This is trial and error process depending on
phone/platform/tablet you have. Some use the current version, some require a prior version.
