CGO-ET and models
I just got the CGO-ET and I set up a new model for it by copying my existing H model (to preserve my rate settings. Does this carry over with the model or is it global to the controller?) I bound the H and the camera in the new model. When I switch between the models, I still have to manually change the camera. Is the camera selected supposed to change with the model? It appears that if I try and use the same model for both cameras, I'd have to rebind every time I change cameras. Is this the case? Anyone with experience here that can shed a little light on this for me? Thanks!
I think the rate settings are global and will apply to any model created. Even though you can create a model with a different camera you still have to rebind when you change. That is because the controller can only be bound to one model and camera at a time so it only "remembers" the camera and model which were last used.
airconditionerservice
