CGO-Et Atmospheric Temp calibration
I've flown several missions and when I bring up the thermal camera, there is no variation in colors... I checked the scale and it showed 378 - 575 degrees!
When I checked the settings, the default Atmospheric Temperature is set to 575.6.
I change it, but it goes right back...
What am I doing wrong?? Thanks...
I can't see the entire screen in your picture. Is the Temperature Range turned on?
Not sure if it was or not. Would that make a difference in the "Atmospheric Temperature" reading?
I can look again.
I would have to get my camera out and check it. Maybe later tonight. I presume the Atmospheric Temp is the background temp.
ardigitalmedia
