CGO2+ Doesn't move after power on
I have a Q500 drone with a CG02+. Unfortunately, she can no longer move.
It doesn't seem to be able to initialize itself when you turn it on.
Photos and video functions work perfectly and the LED on the camera lights up green.
The control board, on the other hand, only starts up partially and a red LED then flashes twice for a second. off and blinks again 2x and continuously.
Furthermore, it emits a synchronous sound to the LED signal and the camera moves back and forth slightly...
Do you have any idea what could be causing this?
I've also tried the 45 degree trick. Unfortunately without success.
If the 45 degree trick does not work the camera will need to be sent to a Yuneec service center for a full IMU calibration. You should also experiment with other angles. Sometimes you can tilt all the way vertical, or over on it's side. Eventually the calibration will drift too far for anything other than sending to the service center.
Thanks for the tip. I'll try that once. If this doesn't work, I'll probably have to go to the Yuneec service center.
Thanks for the help
Reactions: WTFDproject
ReparacionDronesMedellin
