CGO2-GB Camera to Body Harness
I had a minor crash and my wire harness connecting my camera to the body had 2 wires pull out of the pin connecter that inserts into the body. Other than purchasing a new Wire Harness (YUNQ500127SVC) has anyone had success inserting the wires back into the pin?
You may find reinserting the wire into the pin to be difficult, and harder to crimp. If you are sure of which wire goes to which pin, you can release the latch on the pin and extract it. Then solder the wire to the back of the pin so it can be reinserted into the connector.
Reactions: Pier2162
Did the wire pull out of the pin, or did the pin pull out of the connector?
the Wire pulled out of the pin. the pin remains inside the connector. (only 2 of the four wires pulled out.) I tested the camera with the wires out and it comes on. However, the tilt controls have been lost so I am assuming it is wires "3" and "4".)
PerfectPlanqa
