CGO3 4K 3-axis Gimbal Camera moving very slow
I have noticed lately on by Q5004K the camera (CGO3 4K 3-axis Gimbal Camera ), it is very slow to move when I am toggling the switch to adjust the angle it may be pointing straight forward and I move it either fast or slow to point more downward and there is now a long pause before moving, have any of you had this issue or know what may be causing it and if so what is the fix. I will be calling Yuneec to see what they say as well.
That happens so frequently on mine it's a real pain trying to get any sensible footage from it. If Yuneec have any answers for you I'd love to know what they are.
Xol.
Just a suggestion here.
If I were having this issue, I would run the firmware update for the ground station again, or for the first time if you haven't.
Take it for a flight to see if it changes. Actually, you can test it on a kitchen table. It doesn't have to be in the air. You may need to disable GPS.
I would also run the firmware update for the CGO3 again.
Just a suggestion.
x640536786
