CGO3+ Damper Issue
Y
Yuneec Pilot
Guest
IMG_4567.JPG IMG_4568.JPG IMG_4567.JPG I checked my Typhoon H for an upcoming journey and discovered that two of the four rubber dampers connecting the camera unit to the Typhoon H are loose, because the plastic screws have disappeared. Has anyone noticed this kind of flaw before and might know a solution?
It only comes with 2 plastic pins. The two that came loose is just from handling or the occasional rough landing. Just push them back in the holes and you should be good.
I saw this on youtube and it might be some help?
He use a rubberband to prevent to lost the cam.
I wrote to Yuneec about this. It is by design and asked the camera to break away when struck in order to minimize damage.
If your video looks like crap because of vibration, refer to the video to find the reason. Installing that rubber band defeats the damping capability of the gimbal-completely. The only gimbal issue was with the OP not understanding it was correct as it was.
Reactions: Dr Delta
gocdunn
