CGO3+ gimbal error, unknown beep code
Hello,
I have first problem with my CGO3 + camera. Gimbal stopped working without any crash or impact, it only generates beeps codes. Video is OK.
I found information about beep codes on this forum, but my code is not there.
I have beep code: four long beeps and three short beeps.
Unfortunately, in the Way To Fix Drones project, I also don't see a solution.
Does anyone know what it means and what needs to be fixed?
Best regards,
Rafal
Hello,
Best regards,
Rafal
The four long beeps at the start of the code imply it is also an IMU related failure code. However, I was not able to create it and therefore do not have a way to know the exact failure involved.
You can check the IMU connection on the gimbal board, look for a damaged wire anywhere along the route, and look for a bad solder joint on the IMU itself. The IMU sits inside the camera, on a small shelf just above the camera lens.
The possibilities also include a failed IMU or a failed gimbal board. The IMU can sometimes be replaced without calibrating the camera, sometimes not.
I have some other projects underway at the moment. It will likely be several days before I can generate detailed guidance to physically replace the IMU.
Reactions: Murray Martz
For sure is this guy circled there in the picture attached. Look for broken wires you can use a multimeter and check the continuity of those 3 wires.
Hello,
Best regards,
Rafal
I have the same issue and beep code with my CGO3+. Hope someone knows what it means.
Telefoni
