CGO4 Main rotor screws
Hello everyone. I need some help regarding the CGO4. Recently I saw a oscillation in the video recordings. After inspecting the camera I saw that the main motor (the one that spins 360°) is being held down only one screw. Even though I see there are 3 holes that are on that motor. Anyone has taken one apart to tell me what screw sizes are on that motor? Or are the screws all the same size? Thank you all.
If you are referencing the 3 screws that hold the mounting / connection plate to the underside they are 2.5m x 10mm
this photo is on a mount we make for users that have no camera or want to add a 3rd party camera. It uses the the 3 hole under
the gimbal.
the gimbal.
I believe he is referring to the screws that mount the yaw motor to the gimbal mount. A photo from the OP might give us a better idea of what screws he is referring to.
Here is a photo with the camera. It only have a screw in the top central hole . I tried to put screws in the other two, but they spin free inside, so i'm thinking maybe the threads are gone.
Thank you all for the reply's.
dharminder
