Connexion UAV Tool Box
Bonjour Tout le monde,
Comment puis-je connectr mon Typhoon H Pro avec UAV Tool Box, afin de créer des missions, sur le terrain? Est-ce que je peux connecter la ST16 sur le WIFI via mon Smartphone et continuer à voler ou est-ce que cela va perturber le vol ou les fonctions de la ST16 et du Typhoon?
Merci pour votre suivi et à tout bientôt.
How can I connect my Typhoon H Pro with UAV Tool Box, in order to create missions, in the field? Can I connect the ST16 to WIFI via my Smartphone and continue to fly or will it interfere with the flight or the functions of the ST16 and the Typhoon?
Can I connect the ST16 to WIFI via my Smartphon? No. For what reason, what is the use case for that?
You can create missions in UAV Toolbox without being connected online in the ST-16. If you need maps to do so you can use the phone as a hotspot to connect the ST-16 and allow loading the map, but the ST-16 cannot be connected to both the phone and camera at the same time.
dharminder
