Controller upgrade "cruise control".
Hello, I want to share the experience of improving the controller for the Breeze.
If you place the gaskets under the control levers (sticks) of the controller, the levers can be left in any position you choose. For example, the left lever for 1 o'clock and the right lever for 12 o'clock (don't forget to use vertical angle of lever (stick) to control the speed).
After adjusting stick's for best speed and trajectory, you can leave the controller on the table, and it will maintain the course you set. You can enjoy coffee at this time)
The speed will remain the same, no random swings, you can move very smoothly and slowly. Also you can record video in 4k with better stabilization.
If you want to correct flighting trajectory I recommend to use left and right buttons of "camera cross stick" by slow or rapid click's on preferred sides.
Ludwig
