Corrupted jpg images
Merseyside, UK
Hi folks. Has anybody seen this before, or know the reason? I shoot in RAW & JPG with my TH + CGO3+. Occasionally I get a corrupted JPG image, but the accompanying RAW image is fine. It's not a huge problem, as I normally process the RAW versions anyway, but I curious as to the problem. 1601716018YUN00389.jpgYUN00249.jpg
I've seen someone posting similar pictures/problem a good while ago...maybe something like two years ago. I forget what our community's solution was. Try a search and see if you can find the thread.
I had that problem and it was caused by an old hard drive that decided to go south. I tried reformatting the drive which worked for a short period of time.. I ended up throwing it in the garbage. I also tried several file recover programs to no avail.
My personal advice to try another SD card and see if it continues.
Ludwig
