Cruise and camera settings
Ok I see the cruise control will probly work on the 920 st16 but the camera select pad doesn't change camera settings also what does the speed control slider do on the 920 plus
Indeed, the camera D pad is dead when in 920 mode. Cruise control functions just like it does with an H though. The speed slider does as well.
Fast is a relative term for the 920 as it is not all that fast when GPS is on, but yes. The speed slider adjusts the speed it does things up and down. Note that a descent with the slider in the slow position is very slow so if you are low battery you may well need to up the slider to get down from high in time.
Ok thanks ParR .Oh I called yuneec they put plastic props on the new 920 plus and have none to offer so ill have to order more carbon fiber
marcojanson67
