Guys this concept of tethered drones seems to be taking off as of a couple years ago. The systems right now cost over 3k and do not include the drone. I'd like to be able to collaborate with others that are interested in developing this idea for their own personal recreational use. I have some electrical and electronics knowledge and I understand the overall strategy of the tether and on several other threads others indicated their desire to have this system for personal use. I have a custom battery tray interface that i made several years ago and it will be the starting point for the project.
Keeping the Typhoon H in the air has a demand of 25amps anywhere between 15-16v this is approx 375w. During peak demand that climbing or manuvering it can pull 65 amps.
The strategy is to run high voltage AC up the lightest possible cable than has the electrical and mechanical properties needed and once the high volatge enters the tray it would need to come down to 16v 25 amps DC.
The tray should house a small 4s battery anywhere from 800 to 1500mah and the nessesary electronics to provide the voltage and current demand. The tray total weight for the components including the battery and 200' of wire shouldnt be more than 700g and needs to fit inside the tray which has a clear space of 142mmx49mmx43mm.
