E20Tvx radiometric data
The bear is so much. Better is to ask for the rJPG SDK... (Pix4D)
And when I asked for some photos, no one responded... Doesn't matter. If you get something from the Yuneec, tell us at least what you have got if not to share it.
P.S. I'm pretty sure the temperatures, measured by this camera are very questionable. For example, the distance, emissivity, and reflexivity should be added on the low-level DLL calculation, not on high-level thermal data to rJPG transformation. Can you manipulate them via the remote?
I don't know exactly what you mean because I uploaded a lot of files when I was asked. sorry if i missed you. There were a lot of photos in the whole thread.
I'm not a computer specialist and I don't know a lot of the things you do here. I'll ask Yuneec what you said and then I'll let you know. I would first have to find out what rJPG and SKD mean. I didn't even know how to look at exif data from pictures before.
btw, yuneec customer service is very slow and hard to reach anyone there.
I can set the camera between high and low intensity but not much else. Many thanks again especially for you Valkin for your cooperation! You were the key.
Again, thanks a lot guys
Here yes. I asked a month or two before. Doesn't matter, everything is OK.
SDK., not sKd. Or you'll find nothing.
The EXIF data is a machine format, which should be handled by tools. not by hands. Helmut has a tool, which is open for improvements.
This probably is related to the visual part of the camera. The thermal part has a lot of things, which should be taken into account if you want to have a real radiometric image with true temperatures. For sure this will be never possible with the Yuneec closed source camera. I'm curious about why they added thermal data at all, but this is probably the answer to the owner's requests.
That's right. I'm going to start looking for fawns this year and don't need exact values for that. It is also sufficient for finding defective solar panels, but for the future these are all things that should be clarified.
There is very little that can be done or changed in the control settings. I hope the manufacturer works on it.
Everything seems to be correct on this solar field.
The pricing is not ready yet. First I start with fawn hunting and wild boar hunting. But I myself only provide the technology and fly the drone.
Exactly not...
Ok maybe I can recognize a few conspicuous stripes on some of them. Or in the upper area a complete row is defective... But I also have no experience with defective solar panels so far...
Happy that your camera works now as you want. Keep us informed about your progress. Good luck!
Thanks i will do that.
Have a good time!
@FrankS how do you fix the problem with E20Tvx-Pictures and YuneecImage?
I can't manage to evaluate the images from the e20tvx ... :mad:😭
Did you apply the firmware to the camera that is the .bin file in the three files associated with YuneecImage?
Upload an image and we’ll see if we can get data from it.
As shown in earlier posts here you have to have your local settings set to English (or Chinese).
@Lothar Beckert
you have to do what DoomMeister wrote. Load the latest firmware on the camera
here: YUNEEC Europe Shop
and change the system language to english. Swiss German also work.
Reactions: DoomMeister
Hello @DoomMeister, hello @FrankS ,
at the moment i changed my system to "German(Swizerland)" and restart the computer.
Before a view days my H520E was in Service. All components have the latest firmware!
Before a vie minutes i tried it again --- and FAILED :-(
Now i am "at the end of the street" :-(
Java doesn't matter. Is necessary to change system localization, which is not system language at all.
Add some screenshots what are you changing. In explanation use your native language, and to follow the forum's rules, add a machine translation. The last your post is not straight undersdtandable.
Hi, I do thermal inspections of solar fields with the new camera E20Tvx.
The Yuneec Website says:
“Thanks to radiometric technology, the E20Tvx can measure the temperature of an area by interpreting the intensity of an infrared signal reaching the camera. It collects the data for every image pixel, which can be then easily uploaded into standard software for further and accurate analysis and reports.”
But my software partner did not find any temperature data for analysis.
Is there any special Yuneec software to get the radiometric data from the JPG files? Is there any camera setting I did wrong?
Thanks for your help!
Hello,
have you already found a solution to the problem?
I am still looking for a program that can handle multiple thermograms, programs from other companies do not read Yuneec thermograms. Maybe you have a way to get around this?
Maybe you have any information whether Yuneec intends to provide such software?
In this zip folder you will find the files and programs required to evaluate the radiometric images from Yuneec thermal cameras.
The program is called Yuneecimage.exe in version 2
The Zipp folder seems to be too big to attach :-(
Ich bräuchte eine Mail Adresse um den Ordner zu senden.
The folder is approx. 101 MB in size
SsHunter1401sS
