the st100+ will not connect to the quad copterYou can get all the manuals and such here Q500 Series
What exactly are you attempting to reset on the system? There is very little that can be adjusted on the system.
and thank you for the replythe st100+ will not connect to the quad copter
ok i will try it againRead how to create a new model and placing the aircraft in the bind mode. I’m on my phone and don’t have the Q500 4K manual handy to give a reference page.
yes but i also found out i have no files tx or rfDid you find the instructions on page27 of the Q500 4K user manual?
thank youYou can find the instructions for updating the ST10+ and the firmware here ST10+ Controller
I did the factory reset assuming that it would just get the previous owners controls setting undone. Now my issue is on step 37. Nothing is showing up for "model"You can find the instructions for updating the ST10+ and the firmware here ST10+ Controller
You need to create a"new model" then, after selecting it, you have to bind transmitter with the drone.I did the factory reset assuming that it would just get the previous owners controls setting undone. Now my issue is on step 37. Nothing is showing up for "model"
Correct st10+ q500 4kPlease clarify a couple of things:
1.) What drone and what controller? (ST10+ and Q500 4K?)
2.) Did you also do a firmware update? If so, what instructions did you use?
I've got that part down (every step until 37 has no issues). I'm just not getting any options under the "Model" column, but I do for the "camera" columnYou need to create a"new model" then, after selecting it, you have to bind transmitter with the drone.
Several sets of instructions have been mentioned in this thread. And you mentioned "Step 37" a couple of times. Please confirm this part is from the "Q500 Binding Verification"?I've gone all the way back through the process again, following all instructions to the letter...
I'm usingSeveral sets of instructions have been mentioned in this thread. And you mentioned "Step 37" a couple of times. Please confirm this part is from the "Q500 Binding Verification"?
If that is correct, the issue then becomes the controller itself. You had mentioned earlier you did an update to the ST10+, and that you were not sure you it went right. I can't see that you confirmed using the guidance for doing an ST10+ Firmware update. The current guidance is similar to the version mentioned above, but has updated links to the correct firmware, which includes the TX files. Please look at Attachment 36 (ST10+ Firmware Update) of Way To Fix Drones project. That guidance will ensure the TX files are properly loaded.
As you can see in the picture I posted earlier, there is no white text in that column.You can find the instructions for updating the ST10+ and the firmware here ST10+ Controller
