File manager has stopped.
Burlington VT
When I go into the controller and open up file manager I can open up everything except the video file. When I attempt to do so I get the message, "Unfortunately, the file manager has stopped." Suggestions on how to "restart it" would be appreciated.
Also, any suggestions on how to reset the clock for DST. The closest named city in the list is New York but it is standard time and I do not see how to move the time ahead one hour. Thus all the flight times are off by that one hour.
Thanks in advance for the help.
Paul
Do not try to 'fix' the time - it won't work. This is a known bug. Whatever you do to change the time, the next time you connect to the Typhoon, it will pull the time down from the GPS lock - and not apply any summer time adjustments. So it's an hour out for half of the year.
If you want to play videos, you need to either use the play button in the normal Yuneec Flight Mode app, or a dedicated video player / gallery app. Or UAV Toolbox... :D
dubiousflyer
