Firmware 3.01 no calibrations: PROBLEM SOLVED
Italy
In my post
Post your results of the 11-16-2016 firmware here.
I indicated:
"Now no longer work:
- All calibrations: icon and menu are active, but nothing happens
It did not do anything to erase (I had already done) and erase again the FlightMode data.
Instead, I resolved by making a copy of the model "Typhoon H", named "Typhoon H 2" and doing the bind with this.
Already with an earlier firmware release, to bind on a copy of the model, rather than on original, I had solved the problem (a different problem, however).
I hope that this trick may also be useful to others.
i just erased flight log went in selected h pro and rebinded the copter and cam then waited for sync in main pilot screen and calibrated fine
had an issue yesterday tried for three hours to cal bird wouldn't respond i just got it yesterday and before doing anything i updated cx and tx and after that i could not cal nothing till i erased flight data this morning now everything works as should.
misterfantastic
