First crash. Gimbale wired cables - after FIX Up/Down Cam problem.
Hi Everyone.
I'm a beginner pilot. Yuneec Q500 4k.
I'm flying in smart mode only. During my third flight I had an accident. I completely lost control of my drone. Fortunately my quadro finish on tree.
I had a simmiliar situaktion like moste people on forum. I had broken wire on gimbal.
I welded broken cables. When i powered on radio and drone - camera is working, gimbal is working also, but stearing up/down finction is not working. I replaced cable between gimbal and drone (second one from accesories) - unfortunately camera still is not reaction on up/down controls.
I looked on mainboard in gimbal and I dont seen 2 electronic elements (diod or resistors) next to white socket on gimbal to drone calbel. I have in this place only weld points. Model my gimbal mainbord is 1534.
Somebady have any idea's why up/down is not working?
Thanks a lot.
Grzegorz
First, try rebinding the camera and box.
Next, try reloading the firmware in the camera and the drone and see if fixes it.
Reloading the camera firmware worked for me when I had a similar issue.
Let us know what you learn and good luck,
Jafo
Jafo - thanks for reply.
I tried upgrade firmware but i have latest alredy. When I inserted SDcard camera wasn't made upgrade again.I can't connet by USB - I must contact with supplier because I have USB-Drone connection problem from begining (I tried on few computer with different system and with different adrivers). Do You have any idea how I can upgrade camera firmware if latest was'nt upgrade again on this same version?
daps20
