Fix CG03+ broken- anyone in South africa who could try it for me? For a fee obviously?
Looks like only the plastic housing broke- but what do I know. Any experts out there in RSA? Im in Pretoria.
Best
Alan
Does the camera power up and operate normally (except for some motor whining noise)?
If so, the broken housing front, nose piece, lens filter, antenna and microphones of your CGo3+ are the same as a later variation of the standard CGo3 camera. They can be replaced using the first and last few steps of a larger piece of guidance already contained in "Way To Fix Drones project". See Attachment 9 (CGo3 Core Assembly Replacement). You will only need to perform Steps 1 through 6 to remove the damaged cover, and Steps 31 through 38 to install the new one. A small Philips head screwdriver is required for the 4 screws.
Reactions: DoomMeister
thank you for your guidance, WTFDproject and apologies for the delay in responding. Ill check out the guide. Best regards and happy new year.
fabricolaundry
