Flight battery storage voltage
Melvin Michigan, In the thumb
I know there have been several post about battery voltage.
Has anyone come up with an ideal STORAGE voltage?
I know it should be approximately 50%.
I have run down one battery and going to fly the other one again tonight.
3 day weekend is over so not sure when I will get to fly again.
This will be fun checking the voltage every 10 minutes or so to know when to remove it from the charger.
Not a bad little charger if it only had a storage setting on it.
How about your charging time?
Any idea to shorten the charging time? thanks!
Yeah. Charge the battery on a high quality, kick *** charger instead of the lame factory supplied Yuneec charger. Then charge at 1C. Oh wait, this currently is not possible unless you have an adapter for the silly propietary connector, or have modified the charger as was done by @Andyzonk and @34Ford.
Sorry for the sarcasm...it's just very frustrating.
Jimmyray
