Hello actually, videos should now be set, but has not yet worked because of the format. H. elsner will see if he can convert the videos. On Saturday I made about 12 take-offs and landings on the water and by increasing the floats, the camera is so far out of the water that it does not get wet. First of all, about the flights with the Q 500. The camera remains absolutely dry. With the TH, which I will soon test on the water if the weather permits, the camera is even higher due to the floats. I'm absolutely not afraid of that and anyway, after such water flights at home, I will work lightly with a hairdryer to be on the safe side.
Greetings to all hamsters
