GiFi 8050mA flight time
After 11 flights and charged with EV PEAK DY3 the result is about the same as my previous post = 21 to 22 flight minutes under about same conditions. Maybe a few degrees cooler.
"Just did two non-scentific flights with my new GiFi 8050mA battery. No wind, 23C - up and down, left, right. 360 turns and so on. Cam recording. Started on the ground for 7 minutes for sats lock, no leds and no motors running. Total time @ first 14,3V warning = 29min 16sec resp 30min 14sec"
That s still impressive ! Do you have to get that extended battery holder with the 8050 ? What s your overall impression? How s the weight heavier or about the same ?
It's100% the same dimensions as the original TH battery = no extended battery holder. I haven't weight it. So far I'm very satisfied.
Alvaro
