Gimbal guard
Washington state
Gents I see that Amazon sell a gimbal guard for the Q any thoughts on it or is it just a waste? all it is from what I can see is a plate that goes from one landing gear to the next so if you do crash it prevents the camera from taking a direct hit? but you would think that the camera would separate from the rubber attach points anyways?
It will indeed separate. You want to avoid that if you can.
The biggest issues you will find with the guard are two fold....
First... they tie on with simple zip ties. This is okay if you have plenty on hand.
Second, if you store your quad in any kind of case,box or backpack it wont fit with the guard attached and you will need to remove it each time for storage. (extra zip ties)
I've used mine one time.
Good luck,
Jafo
misterfantastic
