Gimbal Up & Down Control on H?
The thing that drives me nuts-est about the Q500 is the delay on the U & D Gimbal Control. Going straight up (or up and back) while keeping a property centered is made difficult because of the lag.
Will the H have the same lag? I understand the P4 does not have it.
Now that would be good to know. I agree the delay on controlling the up and down with the slider is a mystery to me. This is a direct radio input and should be acted on by the camera instantly.
So when you slide for example. to tilt the camera down, it delays and does not move immediately ? That would be a nuisance
That is how the Q is, and it's extremely annoying as you'll pattern overshoot your gimble adjustment on the proportional switch.
Thanks Dabeechman, the H will be my first Yuneec, so that is good to look out for on it, the Phantoms move nicely, hope it is corrected on the H !
Its the same way on the Chroma, another Yuneec product. There can be a lag measured in seconds between the time you move the slider and when there is evidence of a corresponding movement of the gimbal.
Ludwig
