- Joined
- Mar 29, 2018
- Messages
- 1,254
- Reaction score
- 223
- Age
- 73
K
Keith, please bear with me here as I try to understand...
I believe this has been asked before: what does the warranty status of your aircraft have to do with contacting Yuneec to see if they have any ideas as to why your aircraft is behaving as it does with respect to this unpredictable [refusal to] land issue? Talking to them is not going to cost you anything. It just might enlighten you as to what Yuneec has found to be the cause of such behavior. Perhaps others (just a chance) have experienced the same behavior and have called in, allowing Yuneec to research if they were not aware already, and provide a game plan for remedy.
Also as stated before, if you are not willing to get the manufacturer's advice, and are hinting at the fact you are not willing to pay for a fix ("it's out of warranty"), then why, may I ask, are you continually writing about the same issue, post after post?
Your aircraft is going to act the same way unless:
1) either a software/firmware change is made and applied to address the issue,
2) a component or assembly is determined to be the cause and is replaced,
3) an environmental condition is discovered and either you alleviate the condition or change the location of your flights.
With all due respect, something has to change in order to expect different results than what you are getting.
My intentions are not to get on your case but rather help in the way a doctor might say: "If you are not willing to change your eating habits and your activity levels, don't expect much to change with the ol' body, mate!"
Respectfully,
AeroJ snuck in just as I was hitting "Post Reply"... decided to add on...
Then maybe if Keith calls in as well, and anyone else experiencing similar issues, perhaps someone might look into this a little bit more.
I will call in
Keith
