Has anyone had an issue with the H Pro not rebinding to the ST16 after that last update? Or this issue in general? CGO3+ camera is bound showing image but no data showing for the H. I have done the 45 degree tilt with no success, any thoughts?
Yes, even tried to create a new slot. Tried binding to both but not getting a blinking orange light nor does the H show in the list of the aircraft. It like the ST16 is ready the camera but doesn't see the H.Did you select the MODEL TYPE before you attempted to rebind?
*reading the camera but doesn't see the HYes, even tried to create a new slot. Tried binding to both but not getting a blinking orange light nor does the H show in the list of the aircraft. It like the ST16 is ready the camera but doesn't see the H.
Perfect! Thanks PatR, that did it. I appreciate the help!This is so common. Put the 16 in Team mode and refresh the list again.
Yes, I switched mode back to single once it had rebound to ST16.Do you put it back to single mode once it's bind?
