h520 - start video capture command failed.
the camera is connected to the craft/st16 via the wifi link. I have visual of what the camera sees but when I try to commence video recording (in flight or on the ground) I ge the message "start video capture failed". I have downloaded/installed the latest firmware and have calibrated the gimbal. I have also upgraded micro SD to SanDisk Extreme 90MB/s 64GB microSDXC micro SDXC micro SD Card Class 10 UHS-1 U3. What am I missing? what am i doing wrong?
Try formatting the card from the ST16S menu.
Sometimes, at least in the previous version, It would make that mistake when It was actually recording already. You cannot give the order to record when you are already doing so. With the latest version I have no problems and use the same card as you.
Reactions: halfblindrabbet
With whatever you tell us, to help others in case of need :)
Dvca441772
