H520 will not upgrade firmware
get this message on my controller, what to I do to fix it?
Qgroundcontrol supports px4 pro firmware version 1.4.1 and above. You are using a version prior t that which will lead to unpredictable results. Please upgrade your firmware.
I try to update and will not work.
let see what is the actual firmware is on this h520 first. power h520 no props on with camera attached I quessing e90 that you have. start up the st16s controller once data pilot loads up. go to the menu option in one of the tabs it will tell you the firmware number that's in the unit. here are the number you want flight control is 1.8.0-1.6.11, camera not sure which one you are using if it is e90 numbers are v1.0.61_A for north America or v1.0.61_E for Europe. gimbal numbers you want are v2.40.3. now data pilot number you want is 1.5.10.18. What is your update pilot version number it needs to be 1.5.06 to work correctly. make sure you have a good sd card in the camera to do this.
Reactions: Elminte
Is that the only camera you have for it? if you have a e90 or e50 place those on the h520 and see what comes up.
dharminder
