Good morning from Texas! Just wanted to post an update that I think after about 70 flights we have the H520E RTK dialed in. The v2 DataPilot solved the turning behaviour but we have a load of other bugs and enhancements to deal with and are pushing as hard as we can to get some movement.
When we started we were getting average camera location RMSE's of about 30cm horizontally and 20cm vertically which doesn't make sense for the vertical to be lower unless it was the flight behaviour affecting the horizontal positioning. It's a ton better than without RTK but a load of GCP's. Unfortunately it was still not acceptable but I think something happened in v2 and the way we are configuring flights because we are now getting 16-18cm horizontal and 5-7cm vertical.
The flight changes involved making sure to manually set the speed at 10-14mph depending on the overlaps we were running which puts the capture interval at about 2 seconds. Unfortunately the algorithm they are using for setting the rest of the parameters based on overlap and speed is now overestimating the battery and it is usually about 20% more required than what the time estimate shows. If you do not set the speed manually the aircraft always defaults to 22mph which is ridiculous so it is one of the items on our list.
![1635166928142.png 1635166928142.png](https://yuneecpilots.com/data/attachments/26/26770-d369b49dfc80a07d0156b823b7b4216c.jpg)
