H920 Plus Binding issue - ST16
Hello.. I need your help with H920 +. I can do to repair the equipment. Please thank you in advance for your help.
The images show the problem I have with the drone.
Press the Pad button at the bottom left. Go to Settings, Wifi.
Do you see the CGO4 in the list of available wifi's ?
If so, select it, select Connect and put in the password. 1234567890.
Hello Mike... Thank you for your information. But when try go to settings it's no possible. No show the next option. This is shown in the pictures taken.
Your controller is stuck in the "Camera is not match" loop. The problem is the WiFi module (YUNST16111SVC) in the ST16 has failed. Contact John Mitchell (@Yuneec Skins).
"https://yuneecskins.com/all-products/ols/categories/yuneec-controllers?page=2"
Here are some search results for "is not match". You may be able to find more detail.
"Search results for query: is not match"
Thank you so much WTFDproject.
I immediately get in touch with Mitchel and look for some solutions that you indicate to me.
Best regards
xbytesolution
