H920 plus & cg04
Bonjour
Qui peux m’aider avec ce problème quand je branche la caméra sur le drones h920 plus l’application de vol ce coupe je ne sais pas pourquoi merci cordialement avec télécommande st16 et caméra CGO4
Hello
Who can help me with this problem when I connect the camera to the h920 drones plus the flight application this cut I don't know why thank you cordially with st16 remote control and CGO4 camera
The camera is not bound to the controller. Go into System Settings, Camera Select, and select CGO4. Then go to the Bind menu and select Refresh. In the right Camera column you should get the SSID displayed. Select that and press the Bind button on the lower right. If it asks for the password it will be 1234567890. Exit back to the main screen after successfully binding. You should then have video feed on the main screen.
Merci de votre réponse mais au départ j’ai bien un flux vidéo qui s’affiche d’environ 1 secondes puis il disparaît et l’application de vol ce coupe et reste dans cette position a rechercher en permanence
Merci
Thank you for your answer but initially I have a video stream that is displayed for about 1 second then it disappears and the flight application cuts and remains in this position to be constantly searched
Thanks
This sounds like the Controller is having an issue keeping up with all it is trying to do. Possibly a hardware issue, but also possibly an issue with firmware.
Have you done a factory reset on the controller to clear out any APPS that may be compromising the ability to handle the normal controller tasks?
Did the system ever work correctly?
If so, did anything change between the last time it worked correctly, and the first time it did not? Things such as firmware updates, repairs, changes to equipment, or anything you can recall may be helpful.
Reactions: DoomMeister
Patynowy
