Height and distance reading
I have a q500 4k and the altitude and distance are way off. I recalibrated and that didn't help. If I'm hovering at about six feet it says twenty. The distance is about same.
Thanks for any help
Keep in mind the Aircraft is using GPS to calculate distance from the GPS inside your controller. Accuracy of each is probably +- 10 feet each, or a 20 foot total error. Altitude is measured by and internal barometer with probably the same accuracy. To my knowledge, there is no way to calibrate the GPS or the Barometer.
Reactions: ttilley
Exactly right. However, when you start the motors the Altitude is set to zero. Let it idle for a few minutes and then stop and restart the motors and it may be more stable. The altitude tends to vary with the internal temperature inside the aircraft.
Reactions: ttilley
gocdunn
