help Q500 4K fell out of the sky
Post the telemetry and remote files from both birds. If you zip them they will upload fine.
I had an episode one time...
I took off and had a good flight.Landed and packed everything up and moved a few hundred feet to a new location.
Relaunched the Q and found all controls had reversed. No idea why. Took the Q home and tried to find out what was up.Nothing wrong showed in the telemetry even though controls were reversed.
The only fix was to reload the firmware in the Q. I never had the problem again and have no idea why it happened.
Another time while flying off the side if a mountain, I was in a hover about 30 feet below me when all of a sudden the Q took a dive straight down to the ground. No idea why. It just went down.
Sometimes these things will take on a life of their own and sometimes there is nothign you can do about it.
Added: Look here
CaCa happens...
Only two things could possibly cause it just to fall from the sky...
1. Battery was not secured properly and slid out and disconnected in flight. I don't like the way the battery door just clicks shut should have screw as per my photo.
2. Pressing the red start button accidentally while in flight.
Only two reasons possibly why it can fall from the sky...
1.Battery was not fully pushed in the compartment and slid out during flight further causing a full power disconnect.
I don’t like the battery compartment door too weak in retaining the battery so I used a screw to secure it more firmly.
2. Pressing the red start/stop button accidentally during flight.
Frida Gold
