Help with gimbal mount?
So clipped a tree and my gimbal mount came loose. I'm having a very hard time getting the rubber bushings back into place. I have fat fingers which makes it hard. Lol! Any tips or advice on how to get em on place? Thanks in advance!
I had the same happen to me. I just squished the end and put it into the hole a little at a time. You may have to find someone with smaller fingers to accomplish this task. There's not a lot of wiggle room to work with.
Slip a loop of dental floss through the hole and loop it over the end of the dampener and then pull it back through the hole.
And the dampner has to be pushed in top and bottom so the ring on the ends of the dampner are all the way into the holes correct?
You my friend are awesome! Floss tricked worked amazing! I'm new to the forums so you might wanna make a tutorial video on that. Thank you so much!
Reactions: MedicJTD
I'll have to remember that for when mine come loose again.
I saw jello in recent videos and sure enough had a dampener loose. Amazing how it was mostly smooth with only three suspending. Like the floss trick...
daps20
