Help!
My gimbal won’t stabilize once turned on!
Welcome to the forum emperornorman
As a new member, I would like to point out the best tool for you start to learn to use, it is the forum search tool. Before making a new thread to pose a question, begin with the search tool and look for the answer there. The search tool searches information within the forum. This is not a google search tool, it is just for within the forum.
The search tool is located above the Grey bar at the top of the thread, and to the extreme right. It is the icon that looks like a magnifier glass. That is the search tool.
Enter the key words that you are looking for, then hit enter. This will bring up what has been discussed in the forum, provided most questions had tags added to the thread. Adding tags makes the search function work better for all users.
To add tags to your new thread, you add them at the bottom of your thread post in the tag area before you post your new thread. To add tags after you post your new thread if you forgot to, you add them at the top left of the thread under the title where it says
"Tags: Add Tags"
And finally, when posting a new thread, always make sure to post in the correct area. Post as much information as you can about your problem to allow others to help you solve your problem.
Murray
Reactions: emperornomar
ardigitalmedia
