  1. DerStig
    DerStig Guest
    which is topping out at 50Mbps.
    #1 DerStig, Jun 29, 2016
  2. Ted
    Ted
    A GoPro 4 slung under the H would be pretty cool. I have a Typhoon G and flew with the GP4 under that. The wider FOV created too many opportunities for the props the enter the shot, but the video was much better than the Q500 4K or the H.
    I dislike the camera as well, but it is what it is. Thank you for putting that together.
  3. WilsonFlyer
    Firman likes this.
  4. WilsonFlyer
    There's a YouTube video on how to DIY or you can send it to them.
  5. WilsonFlyer
    So is it a waste of my money? Tell me now before I do it. Lol
  6. WilsonFlyer
    Good 411. Thank you.
  7. Jimmylee
    What other flaws are you referring to?
    Did you go back to the stock lens?
    I was also thinking of going with this lens but don't want to waste $140.
    WilsonFlyer and Wookscat like this.
  8. Steve Carr
    Steve Carr Moderator
    Staff Member
    Bessemer, MI
    What did you use for settings on the CGO3? I never get colors like that unless I leave it in auto.
  9. THoff
    I would be hesitant to draw conclusions from those images. The whitebalance is drastically different but is irrelevant as a measure of quality -- you should set it manually and/or correct it in post. Also, the GoPro image has sharpening artifacts that would be much harder to correct than the issues I see with the CGO3+.
    Steve Carr likes this.
  10. Steak frites
    "Raw" on the cgo3+ isn't really raw. White balance is still important. There is little or no sharpening added, saturation and contrast are low in a cgo3+ raw image. These must be added to have a pleasing image. You didn't mention what corrections you made to the raw images.
    I don't know any details about the GoPro, but there is a ton of sharpening in that image.
    If you discount for color balance and the sharpening, the images are pretty similar.
  11. THoff
    The sharpening artifacts are not a result of the higher bitrate, they are caused by GoPro's overly aggressive default sharpening in Protune mode. Even if you had unlimited bandwidth it wouldn't cause stair-stepping on the roofing tiles and near-horizontal edges -- that is sharpening.
  12. Dragonflyerthom
    Gurdon, Ar
    Well to my uneducated eye, I like the cgo3 photo. The color seem better.
  13. JohnL
    Gratallops, Spain
    Steve, one of my (many) complaints with my CGO3+ camera is the extremely warm (high color temperature) video I have gotten on bright sunny days using either Auto or Sunny WB. It doesn't seem to make a difference, at least with my particular setup. I give you Exhibit A (the only test video I've ever uploaded from my POS CGO3+):
    Edit: Anyone else notice the softness (out of focus) issues here?
  14. WilsonFlyer
    Since the camera unit seems modular to the extent that it is freely disconnected from the multi, does anyone else thing this may have been a short-term solution all along and that another camera (+$$, obviously) is in the works and may become available? Is the interface to the plug/connector documented.? Could third party support easily be added?
    Just throwing that out there.
  15. vidwiz
    I like the sunset setting better for sunny days.
  16. JohnL
    Gratallops, Spain
    I can't believe you said that. That's the stupidest thing I've heard in forums in quite a while (and I've heard A LOT of stupid).
    DroneRanger and OnTheRopes like this.
  17. CAPTAINDRONE
    Ottawa, Canada
    YIKES!!!! I've never heard anyone use skin color as a reference for white balance???? If Donald Trump owned a camera company would the white balance be set to orange? :)
    I agree that the Typhoon H does have a white balance issue so it's best to film in Natural and just do the post-processing white balance adjustments.
    DroneRanger likes this.
  18. LooseSid
    UK
    Yes. Extraordinary comment!
    DroneRanger and WilsonFlyer like this.
  19. charon
    I must be doing it wrong, I'm Asian but don't have the skin tone of lots of other Asians, who also don't have the skin tone of lots of Asians other than them, who yet still vary in skin tone from yet more Asians.
    It's almost like such a broad categorization would reek of ignorance and subtle racism.
  20. Dragonflyerthom
    Gurdon, Ar
    Hey I'm beginning to like this forum more and more. All of the guys here put their pants on one leg at a time. Meaning there is no room for racism period.
