Hitec X2 Balance cable board
Eagle's Eye Video
Global Village Idiot
Premium Pilot
Albuquerque NM
So I have finally purchased a Hitec X2 AC+ charger and charge cables for the H & H+
Which of the labeled 4S ports on the main balance board that came with the charger, do I plug the H battery balance cable into? It seems that it will fit either the HP/PQ or the XH ports. Same port for the H+ charge cable?
Answered my own question, but for the benefit of others, it is the HX port.
Reactions: AussieCate
You will also find that you can just plug the balance lead straight into the chargers balance port. Just be careful of the polarity. I hardly ever use the balance board with my X2.
It won't mess up those 2 unused pins?
The XH port is the correct one.
Just so you’re aware of it, it is possible to make pin contact if you accidentally try to insert the plug backwards. It won’r seat but it WILL short.
  • Wow
Frida Gold
