How do I enable cruise control?
I've installed the new September Firmware. Rebound my bird to my ST16. Recalibrated the Compass.
I've tested the bird, it flies just fine. But I tried pressing the left or right on the bottom right controller to start a cruise control and it doesn't budge. What might I be missing?
It works good, but you must be on your toes knowing where the craft is at.
I believe that Drone Clone was referring to the need to go into System Settings on the ST-16.
If you go to the "Other Settings" menu, the selection "Advance Mode" must be set to "On".
Yep, and later pressing the D pad will bring up a notice on the ST-16 screen that you must acknowledge.
ploomy
