How do I modify the ST16S J3 and J4 rate curves?
Corvallis, Or, USA & Bonaire, Dutch Caribbean
@Ty Pilot published an excellent video describing how to modify the J3 and J4 rate curves for the ST16 (
) with the goal of having smoother motion transitions when moving the joy stick from its neutral position. I would like to modify the rate curves for the ST16S (H+ controller) but Yuneec has completely changed the controller UI. I have attempted due diligence in locating equivalent functionality in the new controller app but I have failed.
Any pointers on where in the UI the functionality to modify rate curve is located would be greatly appreciated.
Thank you.
Reactions: h-elsner
The purpose of this post is to provide closure for my initial request/question.
Per @Ty Pilot,
  1. the ST16S does not provide the ability for the user to access/change the rate curves. The good news is that
  2. based upon his initial flights, changing the rate curves IS NOT NECESSARY! as the H+ has more refined control characteristics :)
catfish
