How to change arm piece ?
The end nearest the drone is sometimes glued in place, sometimes it is not. The end at the motors has been glued on all of the arms I worked with. If there is no glue, you can drill out the rivet and the end piece can be removed without too much effort. If there is much glue at all, I know of no practical way to remove the carbon tube without damaging the end piece.
Yes yuneec skins is in my head for quality parts too. Look my place the other side of the ocean, i found arm 25 euros in Europe (Deush). Plane and $40 or truck and 25,13 ?
Reactions: Yuneec Skins
Are the arms interchangeable between PLUS and PRO?? I looked around for this answer but did not find it. Thanks.
giiir
