How to instal LED lights on the Typhoon H
Hi guys,
Im planning to install LED lights in the likes of strobe and Search lights. Just on wondering how do i install them onto the typhoon? Where should the wires be connected too? Your replies will be much appreciated? Video links to this is good if any.
Thank you
Regards,
Gizmo5
I do not know about search lights, but for strobes, I use these:
STROBON Standalone - Flytron
I stick em on with some velcro, really helps see your aircraft at a distance.
I know some guys have mounted LumeCubes on their H for lighting, but they are only good for close up.
You have to watch how much weight you add the the aircraft, more weight, less flight time.
Hi BobW55
Thank you for your reply. Will look into Flytron.
Thank you again.
Regards
mining_drones
