How to install simualtor to PC/St16?
Hi, I just bought a USB simulator to use with my St16 and H. I have installed the program in my PC but how do I connect it to the ST16? Looked for a youtube but can't find it.. Any tips appreciated.
Open sim on pc and enter bind mode. Go on st16 into bind mode and hit refresh then select the dongle and bind. You might want to copy your typhoon profile and name it simulator so you can easily switch back and forth. Make sure turtle mode switch is all the way up/fast on st16. Have fun
Hi
The UAV Sim has now been upgraded to include the Typhoon H. It took me over 3 hours to get it working due to not being able to bind the sim with the ST16. I did look on the net and You Tube but could not find anything to help. I eventually went through every combination of key i/p’s and finally cracked it. To save others going through the same pain I did, I thought I would post some instructions
This works with UAV SIM V2.10 Dated 18 Oct 16 available on the UK Yuneec website
Enjoy
Setting up a SIM model on the ST16
If you have not already done it, set up a new model on the ST16
ST16 - Model Select -> OK
ST16 - New Model -> Create new model
Type in a name e.g. SIM àSelect model type “Typhoon H” - >Save
PC - Insert SIM UAV dongle
PC Start the UAV SIM
PC - Model -> Select->Typhoon H -> OK
PC – Radio-> Bind Yuneeec USB Receiver
PC Displays “Please set the Transmitter into bind mode then click OK”
DO NOT Click OK YET
ST16 - System Settings ->OK
You now need to find the receiver for the dongle
Go back to your PC
PC should still be displaying
PC - Now you can Click OK
PC should now be displaying
”In the bind menu of the transmitter now select the USB receiver SRXXXX then click OK”
DO NOT Click OK
ST16 - Press Refresh
The dongle receiver name should now appear in the aircraft model window
e.g SR23s_12000.05
Follow these instructions EXACTLEY
ST 16 - Press the receiver name
ST16 -Press Bind, ST16 now displays “Connection established”
ST 16 - Press OK
PC Should be still be displaying ”In the bind menu of the transmitter now select the USB receiver SRXXXX then click OK
PC - Now you can select OK
PC Should now be displaying “In order to establish the connection, return to the transmitter main screen by pressing the transmitters back button twice”
DO NOT PRESS OK ON THE PC YET
ST16 - Select the back button
PC Should be still be displaying “In order to establish the connection, return to the transmitter main screen by pressing the transmitters back button twice”
PC - Now you can Press OK
You should now see
PC “The bind procedure has been completed successfully”
PC - Select OK
Tip 1 The Typhoon H will not take off unless the hare / tortoise switch is set to hare
Tip 2 If you get errors with binding, forget messing with the programme on your PC, it does not help, turn off / on the ST 16 and start again.
Hi
Enjoy
DO NOT Click OK YET
Go back to your PC
DO NOT Click OK
e.g SR23s_12000.05
ST 16 - Press OK
You should now see
PC - Select OK
Hi
Enjoy
DO NOT Click OK YET
Go back to your PC
DO NOT Click OK
e.g SR23s_12000.05
ST 16 - Press OK
You should now see
PC - Select OK
Great instructions: THANKS
paulrs
