This guide is from recent memory and may not be exactly right, but will be good enough to get you there.
Edit (02/26/2019): You will need to place the mode switch to the ‘R’ position which puts the 6606 in the repeater mode of operation before starting the first step below.
Setting up the ZyXEL WRE-6606 for use with the Breeze
1. Plug the 6606 into a power source.
2. Attach the Ethernet cable between the 6606 and your computer.
3. Open a browser on the computer and enter 192.168.1.2 into the address bar and press enter.
4. In the pop up dialogue enter the default password of 1234.
5. Easy123 will then ask for a new password. Enter one of your choice, a second time to verify, then apply it.
6. The 6606 will then reboot and ask for the password you just set, enter it, and continue.
7. Easy123 will then go to 2.4 GHz setup. Since the Breeze only uses 5.8 GHz band, skip the 2.4 GHz setup.
8. Next is the 5 GHz setup screen. At this point turn on the Breeze and when the Status LED in the arm starts flashing green hit rescan on the Easy123 setup screen and then select the Breeze’s SSID and then continue.
9. The next screen is the 2.4 GHz and 5 GHz WiFi setup. You can accept the defaults and apply, or you can change the SSID’s and passwords to your liking and then accept.
10. Now remove the Ethernet cable and cycle power on the 6606. When the outer lights on the 6606 are lit solid, ensure the breeze is in bind mode with the Status LED flashing green. After several seconds the 5 GHz light on the 6606 will start blinking indicating binding with the Breeze.
11. You can now use either the 2.4 or 5 GHz WiFi from your phone to connect to the 6606. Once connected open Breeze Cam and make sure you are connected to the Breeze.
Have fun.
Have fun.
