IPS Error showing in GUI
PL4 8QB
Hi Chaps,
I have an IPS error showing when I connect the GUI
What is IPS?
I Have H realsense version, later model Oct 2016
All firmware updates installed, flies brilliantly, solid as a rock.
Understood.
If you had read the thread I linked to you would have seen that v1.02 has a known problem and that there is nothing wrong with your RealSense (IPS) module.
My apologies, I did click the link but did not scroll down to the info.
Thank you for your help..
Thanks for this info on the real sense IPS module my GUI shows a failed IP and i was wondering to weather this was a GUI v1.02 known problem, does this mean the next update will sort this out.
You will have to ask Yuneec that question.
puputus
