Is H920+ compatible with CCC-based flight planners like UAV Toolbox?
Hi,
so the question is quite simple - there are many flight planners designed for H480, which output files for CCC routes. Can the same flight planner be used for H920+?
Hi,
UAV Toolbox works fine with the H920+. Also, toolbox simply created a CCC route which can be loaded to the CCC list in the ST16. Toolbox yaws the aircraft to obtain camera pan and seems smoother than the waypoint function on the ST16.
gocdunn
