Just Power Light, No Arm Lights No Signal Beeps. After trying to update Firmeware. HELP!
Just Power Light, No Arm Lights No Signal Beeps. After trying to update Firmeware. I see there is a 8GB SDCARD on the ECS board, can this be taken out and reprogrammed using a PC. Any help would be great
No. The SD card is not part of what you are trying to do.
Was there some failure prior to the update that led you to perform the update?
What method did you use for the attempted firmware update?
I tried to put the idividual files on the SDcard and placed in in the C23, all was going well untill I got to the Camera update, it hung on 2%, after that, No lights, I even can't turn ff the drone without pulling the batter
Just wanted to get rid of nown Bugs and make it stable.....I just got the Drone to light up again an see Camera now to just mount the H+ and should be good to go:)
Reactions: WTFDproject
Frida Gold
